SL/R231: Easy Exit Setting?
Old May 8, 2022 | 11:48 AM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Easy Exit Setting?
I have my SL set to enable this feature but I don't observe anything happening. What am I doing wrong?
Old May 8, 2022 | 01:27 PM
ThatsMyDawg's Avatar
SL 400
The steering wheel moves out of your way when you turn the car off and also goes (lowers, raises, whatever) to your pre set position when you get in/start the car.
The move out of your way feature will not happen if the wheel is already in its furthest up position, or you open the door while the car is running. You must turn the car off and open the door to experience that feature.
Old May 8, 2022 | 01:31 PM
rmorin49's Avatar
Veteran: Army
Thanks. Do I have to do anything other than set my seat and steering wheel positions and then enable this feature in the settings menu?
Old May 8, 2022 | 01:52 PM
SL 400
No, other than save the memory positions.
Old May 8, 2022 | 01:58 PM
rmorin49's Avatar
Veteran: Army
Old May 8, 2022 | 08:35 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
I drive with the steering wheel in the upmost position so it does not block my view of the dash board so this function is useless for me…..
Old May 8, 2022 | 08:57 PM
SL 400
Having your view of the dashboard blocked may be different for each person based on the angle you have the seat when driving, as well as how tall you are.
My view of the dashboard is also not blocked, but thankfully I am able to still use and appreciate the easy exit function. I think it’s a slick little feature, although not mind blowing.
Old May 8, 2022 | 09:21 PM
rmorin49's Avatar
Veteran: Army
Originally Posted by ThatsMyDawg
For each person it will be different based on the angle you have the seat when driving, as well as how tall you are.
Does your seat move back when you turn off the engine?
Old May 8, 2022 | 09:29 PM
SL 400
It does not.
File Type: mov
Old May 9, 2022 | 03:39 AM
billvp218's Avatar
m157 SL63
My 2005 SLK55 had easy exit which moved the seat back (along with raising the steering wheel), I don't know why MB removed it for the SL - it was quite handy.
Old May 9, 2022 | 04:49 AM
SL 400
There are a many questions I would like to ask MB about why they did this, or that. I would truly like to hear their mindset and reasoning on some things. I would also hope that the overwhelming theme of the answers they would provide wouldn’t be cost savings.
I will likely never get to ask such questions.
Old May 9, 2022 | 07:33 AM
DrMongo's Avatar
2013 Sl550, 2012 CTS-V coupe, 2015 Grand Cherokee, 2014 Ram 2500
I would use this feature with caution. Mine drove the wheel to its uppermost position and stalled/jammed the motor. Motor would then not respond to the raise/lower lever. Had to yank on the wheel while use the lower function to unjam it. This is not an uncommon issue according to this forum.
Old May 9, 2022 | 09:24 AM
spinalator's Avatar
2017 SL450 2022 GLC300
I preferred my this setting in my old Corvette where the seat would move backwards and the steering wheel retracts as well.
Old May 9, 2022 | 10:06 AM
rmorin49's Avatar
Veteran: Army
I agree as it worked great in my C7 Corvette. I may as well turn it off in the SL if there is no way to get the seat to move back when exiting. Having the steering wheel raise is unimportant to me.
Old May 9, 2022 | 12:33 PM
SL 400
I would be more inclined to have the car serviced to find out why your steering wheel jammed, as there is no way to know that the jam wouldn’t have happened at that moment by you manually raising the steering wheel.
Kinda like saying be careful when putting your car in reverse, because I did and it made my reverse light burn out. Always good to be careful, but also good to find the culprit.
Old May 9, 2022 | 03:54 PM
Jcrew's Avatar
SL 400, GLC300, C300
You are correct that this is not an uncommon issue. My 2016 also jammed but, fortunately, was still under warranty. There is a part in there commonly referred to as a “dog bone”. It’s made out of plastic and is the weak link. You can force the wheel to move but that’s hardly a fix, it’s a temporary solution at best.
Old May 10, 2022 | 04:29 AM
rorywquin's Avatar
Shanks’s Pony
This has been asked elsewhere. However, yes the others are correct & only the steering moves (if not at teh max up position). I have a SmartTop and one of the (many) features it it adds is that you can program the driver seat memories. So when I switch off, the seat will move back and up, when I turn on the seat moves to the driving position.
I also don't get why MB don’t do this.
My 2003 Dodge Durango Hemi, had outside mirrors, a/c, radio, seat, steering, pedals etc programmable to two key fobs (wife & me).
Old May 10, 2022 | 06:03 AM
ToeKneee's Avatar
R231 SL500
You could always program memory 3 to full seat backwards, then just press the button on exit and your normal seat button on entry?
Old May 10, 2022 | 06:13 AM
rorywquin's Avatar
Shanks’s Pony
Originally Posted by ToeKneee
You could always program memory 3 to full seat backwards, then just press the button on website and your normal seat button on entry?
Yea but you have to hold it down while the seat moves. Another feature that SmartTop adds is "one touch” for the seat memory buttons.
Old May 11, 2022 | 08:05 AM
ToeKneee's Avatar
R231 SL500
Yes I know, I also have the smart top module and have pos 3 set for seat full back, something I only need while trying to get out the car in the garage.
Old May 11, 2022 | 10:06 AM
rorywquin's Avatar
Shanks’s Pony
Y........... while trying to get out the car in the garage.
That is the problem with coupés and their long doors.
Old May 12, 2022 | 10:41 AM
octony9717's Avatar
2020 E350L - 2018 SL450
This is a little lame. I thought my car had a problem until I read this post. Not sure why they couldn't tie it in with the FOB like so many other cars do.
Old May 12, 2022 | 02:57 PM
rorywquin's Avatar
Shanks’s Pony
It is all to do with safety. MB do not want a seat or roof moving without direct human input incase, it injures a person.
If you are holding the button in place then you are responsible.
If you push a button and let go while the seat crushes a child then they are responsible.
The roof of our cars folding would certainly crush something on a human being if caught in the wrong spot.
MB have to allow that there are many idiots that will buy their cars.
