SL/R231: Oil consumption.
Old May 12, 2022 | 10:52 AM
octony9717's Avatar
2020 E350L - 2018 SL450
Oil consumption.
I just noticed my oil was a bit low in my 2020 E350 (no notification/another problem). I checked my SL which is OK in this case. This lead me to look up the oil section in the SL manual to see what they recommended for oil replacement.
I noticed it mentioned that the engine could use .9 quarts per 600 miles.
Depending on your driving style, the vehicle consumes up to 0.9 US qt (0.8 liters) of oil per 600 miles (1,000 km). The oil consumption may be higher than this when the vehicle is new or if you frequently drive at high engine speeds.
Doesn't mention the engine though. DUH. I have the 3.0?L.
Seems a bit high to me, any empirical data available on this topic
Old May 12, 2022 | 01:40 PM
iridium18's Avatar
2023 AMG GLE63s, 2017 AMG SL63, 2024 Sprinter, 1958 Chevrolet Corvette
Great Names !
Old May 12, 2022 | 02:15 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
I have owned three SL’s, Two 550’s and one 450 and none of the three use any oil between changes. I drive spiritly but am not abusive.
Old May 12, 2022 | 03:29 PM
octony9717's Avatar
Originally Posted by iridium18
Great Names !
Thanks. Nice car .
Old May 12, 2022 | 05:39 PM
JettaRed's Avatar
Veteran: Army
Engine size usually is NOT a factor in oil consumption as some four cylinders consume as much or more than the amount specified. I would guess that is a worst-case scenario. Honestly, that amount seems like a LOT to me. Unless you have an oil leak somewhere, high consumption would be a sign of bad piston rings or an excessively worn engine or bad turbo bearing seals. My 2004 Audi TT225 with the original engine and turbo has almost 250,000 miles on it and does not consume any significant amounts of oil, maybe ½ quart between changes (every 5000 miles).
Old May 12, 2022 | 08:16 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
My SL400 uses zero oil between changes, annually or 10k miles, Mobil1 0w40 European formula.
Old May 12, 2022 | 11:11 PM
Wolfman's Avatar
Super Moderator
The oil consumption data is not important for the US.
Oil consumption only really happens in Germany when you push the engine for sustained periods.
The last SL we drove in Germany was a newish (3 months old) 2018 SL450 and that engine used a liter of oil in about 1500km during our trip.
This is normal. You should see fuel consumption at full speed
Old May 13, 2022 | 02:07 PM
Bay Leaf's Avatar
SL 350 R231
There has to be tolerance's in bearing / piston rings etc otherwise the motor will seize / freeze up. All engines that do high mileages / cars and indeed trucks will use a a certain amount of oil. I had many years ago a Opal Manta that was in beautiful condition with low mileage, but it did use a slight bit of oil between services which I had no problem with.
Old May 13, 2022 | 05:00 PM
JettaRed's Avatar
Veteran: Army
Some engines are known to have higher consumption than "normal". I had a VW 2.0L AEG engine that seemed to require topping off a few times between changes.
Old May 14, 2022 | 04:34 PM
David2244's Avatar
2013 SL350
Are you using the correct grade of oil?
