SL/R231: R231 Search
Old May 12, 2022 | 03:02 PM
ThatsMyDawg's Avatar
SL 400
R231 Search
Hello all,
Is there a way to search and only pull info related to the r231? Each time I have tried a search it pulls up numerous threads on all models, although I assumed since I was in the R231 section it would pull only those related to R231.
How do you search Model specific threads/posts?
Thanks in advance..
Old May 13, 2022 | 08:21 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Originally Posted by ThatsMyDawg
Hello all,
Thanks in advance..
1. Be on this forum
2. click "search this forum"
Old May 13, 2022 | 11:39 AM
Wolfman's Avatar
Super Moderator
Another way is to use the advanced search for more control of the search results (post vs threads, titles vs full posts and users). Simply select the forum you want to search. The screenshot shows the R231 forum
Old May 13, 2022 | 05:35 PM
SL 400
I appreciate it. I had half right!
Originally Posted by eddieo45
1. Be on this forum
Thank you.
[QUOTE=Wolfman;8563098]Another way is to use the advanced search for more control of the search results (post vs threads, titles vs full posts and users). Simply select the forum you want to search. The screenshot shows the R231 forum
Old May 13, 2022 | 05:57 PM
JettaRed's Avatar
Veteran: Army
While I understand the frustration of search results including other cars, issues may be discussed fully in other forums that also pertain to the R231. So don't neglect to check all forums if you don't get a response in a particular model's forum.
Old May 13, 2022 | 06:04 PM
SL 400
Understood.
Not so much of an issue with responses, I just wasn’t searching correctly.
