SL/R231: Tire question (again)
2013 SL550. Looking at the Michelin Pilot Sports or similar as I remember was constantly recced previously and most were pleased. (just will not let me look over all previous posts on this subject) Think my service guy is giving me the wrong info on the front and rear dimensions needed for my car and wanted to check with you first. SW Florida, mostly Summer weather and don't tend to drive in rain unless caught in it, but looking for as smooth and quiet a ride as possible as wife busted up her back. Price not an issue if they do the job. Many thx.
The only issue I had was the inability to find rear tires in 285/30 size...so I opted for 295/30's which fit just fine.
Michelin PS4s are the best tires for the job. You can also get the original Michelin PSS but those are an older tire design and the predecessor or the PS4s. Eventually though the Michelin PS5s will come online next year or so...
Again, many thanks.
Remember the only difference between a 285 and 295 is 0.4" in width and the resulting diameter changes by 0.9% (larger). Since the Front tire has actually a larger diameter than the factory 285 rear, the 295 is closer to size to the front. Result: no difference...
Hope this helps
Hope this helps
Hope this helps
This is a bad image from our 2013 SL550 but it shows the surface design of the wheel. It's actually diamond cut surface (and a stock image)
Hope this helps
) At least the murky saltwater didn't get into the car as such.2 more inches and the water was about to come inside the house. Anyway, couldn't start her and eventually managed with jump leads, but service tells me batteries are very low and that's why the starter motor button not working and other error messages, so will just have to replace both I think as they are as you know situated in the back low down. This is one time I wish the battery was placed where most others are.
Regardless, technician just called to say I got the wrong size rear tires and I had to assure him they were ok.
Happy you got tires and sorry for the storm damage! I hope the damage is manageable. We had a thread in the AMG GT forum, along with some pricey cars lost in the process. Even cars on the lift didn't stay put; they should have put strapped them to the lift (like on a tow truck).
https://mbworld.org/forums/coupe-roa...ng-paddle.html
I prefer the darker wheels to the originals - looks sportier to me.
Hope this helps
