SL/R231: Brake pad Question
2020 GLC300 -2014 Sl550 - 1997 SL600
These cars do also have brake wear sensors that should in principle alert you via a dash warning light before the pads get too thin. And also, if you have the original owner's manual and booklets, there should be a flat "tool" in there that you can stick between the wheel rims to measure the brake pad thickness.
2015 SL400; 2019 X5M40i
Mine had brand new pads installed by the selling dealer when it went through the CPO process. Immediately after I took delivery I swapped out the pads for a set of carbon ceramics. Reduced the brake dust by about 90%. Also installed new wear sensors on all 4 wheels. A friend and I did the installation in his garage since he has a lift. Very pleased.
'13 SL550 Mars Red, Designo White interior, B and O sound
Thx.
Yes, as I recall there was a sensor on each wheel but I could be mistaken and there may be one for each axle. There are several vendors selling PowerStop. I used CARiD because I had a discount code and they had them in stock.
Just spent $760 in parts, RockAuto, for a complete brake job frt/rr. Pads/Hardware/Sensors/Rotors. Upgraded Dynamic Friction ceramic pads and high carbon rotors. Easy peasy 4 hours of labor in my garage.
Brake Pad Wear Sensor:
2x BECK/ARNLEY 0842081 (Standard Replacement) Front
2x BECK/ARNLEY 0841526 (Standard Replacement) Rear
Pads:
1x DYNAMIC FRICTION 1600168901 5000 Euro Ceramic; Includes Hardware Kit Rear; With AMG Sport Package
1x DYNAMIC FRICTION 1600168801 5000 Euro Ceramic; Includes Hardware Kit Front; With AMG Sport Package
Rotor:
2x DYNAMIC FRICTION 92063103 (High Performance) Hi-Carbon Alloy GEOMET Coated Rotor; Drilled Info Front; With AMG Sport Package
2x DYNAMIC FRICTION 92063102 (High Performance) Hi-Carbon Alloy GEOMET Coated Rotor; Drilled Info Rear; With AMG Sport Package
Pads:
Rotor:
Before I took the plunge and put the AMG Ceramic Composite brakes on my SL450, I tried ceramic pads on the original system. I got them from Porterfield Racing Brakes in Costa Mesa, CA and they were great. Significantly less dust, excellent feel, no squeaking, etc. I highly recommend them.
'18 SL 550, '19 1500 Z71 Silverado LTZ, '19 Mustang convertible
Streamliner Are you saying that only the pads were upgraded to ceramic? No need for the sensors, rotors, etc. to be replaced? I'm hoping this is the case as I would much prefer this route vs having to replace the other parts! And, do you recall the approximate cost?
Streamliner Are you saying that only the pads were upgraded to ceramic? No need for the sensors, rotors, etc. to be replaced? I'm hoping this is the case as I would much prefer this route vs having to replacing the other parts! And, do you recall the approximate cost?
a small, sort of an "old time" shop.
Streamliner Thank you very much, Sir!
