SL/R231: Normal Coolant Temp
Old Oct 1, 2023 | 01:15 PM
Markrtn7's Avatar
2017 SL450
Normal Coolant Temp
2017 SL450. For weeks the normal driving temp has been dead center between C and H. Now, even with cooler ambient temps, it runs at 1 notch higher. Should I be concerned? Radiator looks clear and reservoirs are normal.
Old Oct 1, 2023 | 05:53 PM
JettaRed's Avatar
Veteran: Army
Mine always is at that position once warned up. That's with all the Mercedes I own or have owned. So, if yours is normally at the 9 o'clock position, then maybe your thermostat started working correctly. Was your car always at 9 o'clock and how long have you had it? What's your mileage?
Old Oct 1, 2023 | 05:56 PM
chassis's Avatar
2017 GLE350 4MATIC
Normal for MB. It’s mid-way between full scale readings.
Old Oct 1, 2023 | 08:26 PM
Markrtn7's Avatar
2017 SL450
I've had the car for 4 weeks, has ~43k miles. All kinds of driving since then, but always at 9 o'clock when warmed up, until now. Only change was replacing the engine and cabin air filters. Both were pretty dirty.
Old Oct 1, 2023 | 10:15 PM
JettaRed's Avatar
Veteran: Army
How good or complete are the maintenance records? Was the coolant ever changed out? (Not that it needs to be.) What color is the coolant?
I realize there is a change, but the gauge seems to be reporting normal temps. One more thing, as a new Mercedes owner, get yourself a Mercedes specific scanner--not some generic OBD reader. It will pay for itself almost immediately. You now own a sophisticated automobile and need to be prepared to spend money where needed (such as a good scanner).
Check Amazon for:
  • iCarsoft MB V3.0 (not MB II)
  • Launch Creader Elite Benz
  • Foxwell NT510 Elite
With one of these, you will be able to read the live data from the engine to see what the actual temperature is. Sometimes the gauge in the instrument panel may not be accurate.
Old Oct 2, 2023 | 01:48 PM
JettaRed's Avatar
Veteran: Army
This is mine all the time.
Old Oct 2, 2023 | 03:41 PM
Markrtn7's Avatar
2017 SL450
Don't have any maint records unfortunately. Yes, definitely a learning curve on these cars. I can't even find the OBD2 connector! I have a laptop program that will show live data.
Old Oct 2, 2023 | 04:30 PM
ThatsMyDawg's Avatar
SL 400
Looks normal to me. See my pic below from today..
Old Oct 3, 2023 | 01:21 AM
ToeKneee's Avatar
R231 SL500
OBD connector is under the panel below the steering wheel, towards the front of the car inside a little panel that needs to be dropped down. So find the bonnet release then a little further forward there is a panel that flips open and the OBD pretty is in there. HTH
Old Oct 3, 2023 | 07:46 AM
JettaRed's Avatar
Veteran: Army
OK, hand over your keys. You shouldn't be driving! J/K
Couple of things you can do.
  • Make sure you have registered you car with www.mbusa.com (or wherever you are).
  • Go online at www.mbusa.com and download a copy of the Operator's Manual for your car. (I've attached the 2015 manual.)
  • Go to www.lastvin.com and enter your VIN. Print out a report of your car's configuration so you know what options you have.
  • Go to your local dealer and ask if they can print out the service history of your car. Some dealers will and some won't.
  • Move the driver's seat to the rear, grab a flashlight, and stick your head under the dash. The OBD port is on the left next to the hood release and is covered by a little flap that swings down. (Please tell me you know where the hood release is!)
File Type: pdf
Old Oct 3, 2023 | 01:15 PM
Markrtn7's Avatar
2017 SL450
Found it! At idle at the 2nd notch past C it shows 129 degF, 3rd notch is 145, 4th (9 o'clock) is 162, 5th is 183. At 205 degF it's about the needle width over the 5th notch. So I'd say that's about right, with you guys pictures of about 95 degC.
Old Oct 3, 2023 | 01:56 PM
JettaRed's Avatar
Veteran: Army
I never figured out why mileage and speed are in MPH, yet coolant temp is in deg C! Multiplying C by 1.8 and adding 32 is just too darn hard. I mean, why not give us imperialists temperature in Fahrenheit? After all, Fahrenheit was born German. AND, my fuel gauge is in fractions versus decimals!
