SL/R231: Remove Cluster Arch ???
Old Oct 16, 2023 | 06:35 PM
beerme's Avatar
2003 SL500
Hi, I need to do some leather repair on my dash as the leather is sagging on the cluster "arch" and starting to partially block the view. Does anyone know how to remove the arch and does the entire cluster have to come out with it? I have not been able to find any directions or videos on removing that piece and I don't want to break anything.
2014 SL550 - Florida Car with leather starting to pull away from door panels which I repaired and now the dash is starting to have problems.
Thanks in advance for your consideration,
Regards,
Phil
Old Oct 16, 2023 | 06:45 PM
JettaRed's Avatar
Veteran: Army
Somewhere there is a long discussion about leather on the dash. You'll just have to search and maybe you can find someone that can answer your question. I'm pretty sure it is in this forum.
Old Oct 23, 2023 | 04:53 PM
beerme's Avatar
2003 SL500
Thanks,
I saw a leather discussion, but it didn't address my challenge which is how to remove the dash piece over top of the instrument cluster, does anyone know if it just pulls off similar to the r230?
Old Oct 23, 2023 | 07:22 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Should be fairly painless…
here’s a good thread:
https://mbworld.org/forums/sl-class-...e-removal.html
also see attached pertinent section of the WIS (factory manual)
Good Luck
File Type: pdf
Old Nov 22, 2023 | 10:52 AM
Citation4444's Avatar
2013 SL550
Regards,
Phil
I have a 2013 SL550 Florida car with the same problems. I was able to repair all except this leather sagging down into the instrument cluster. Mine is starting to obscure the view of the gear information. It looks like the "arch" should come off, but from what I've read that's not the case. I'm hoping someone comes up with a relatively easy way to fix this.
Old Dec 21, 2023 | 08:48 AM
KILLERHERTZ's Avatar
2013 SL63 AMG
Hi guys,
Anyone have a solution for this? The link above doesnt related to this issue. Mine is sagging down now also.
Thanks!
Old Aug 4, 2024 | 09:22 PM
lakepappy's Avatar
sl550
Instrument cluster hood
Originally Posted by KILLERHERTZ
Hi guys,
Thanks!
same problem, any solution?
Old Aug 7, 2024 | 05:57 PM
Hi guys,
Thanks!
Sorry haven’t been following this thread but, the cluster panel is relatively easy part to remove once you remove the cluster…
see attached WIS section
Good Luck!
File Type: pdf
