SL/R231: Wjw
Old Jan 6, 2024 | 08:04 PM
Wjw's Avatar
Wjw
Sl63 amg
Wjw
center console drink holder. Too stoopid but true.
Layed a ballpoint pen on center console….opened drink holder flip up door and pen fell into the space the lid occupies when open EXCEPT it will not open to vertical because the pen is laying at bottom. How does one access this mysterious void?
Old Jan 7, 2024 | 01:00 PM
JettaRed's Avatar
Veteran: Army
That sux. But maybe if you look at some YouTube videos about installing the Road Top CarPlay unit, they may show how to remove enough of the console to get the pen out. In the videos, you need to remove the facia around the radio to install the CarPlay unit.
Old Jan 7, 2024 | 01:06 PM
JettaRed's Avatar
Veteran: Army
Try this.
Old Jan 7, 2024 | 01:11 PM
JettaRed's Avatar
Veteran: Army
Or this.
Old Jan 7, 2024 | 04:40 PM
Wjw's Avatar
Wjw
Sl63 amg
Great vids. However I don’t feel up to this level of qualification to dissect my dashboard. I think I’ll keep fishing with a long Allen wrench with bubble gum. This hasn’t worked yet but “sometimes blind squirrels find nuts”
much thanks
wjw
Old Jan 7, 2024 | 04:46 PM
JettaRed's Avatar
Veteran: Army
Originally Posted by Wjw
...but “sometimes blind squirrels find nuts”
No, they never do. Good luck.
Old Jan 8, 2024 | 06:34 AM
ygmn's Avatar
2015 E400 Sedan
magnet stick part getter thingy mechanics have? if pen has some metal.
SE 30-inch Telescoping Magnetic Pick-Up Tool, Extendable Magnetic Pickup Tool for Car, Household, Office & Industry, Stainless Steel, Black Handle - Amazon.com SE 30-inch Telescoping Magnetic Pick-Up Tool, Extendable Magnetic Pickup Tool for Car, Household, Office & Industry, Stainless Steel, Black Handle - Amazon.com
Old Jan 8, 2024 | 09:58 AM
JettaRed's Avatar
Veteran: Army
The magnet is probably too big on that one. I'm assuming it can only be as big as the pen's diameter.
Old Jan 8, 2024 | 05:34 PM
War Party's Avatar
2015 SL550 and 2013 Ferrari California
This is really far out, but I did something similar once. Depending on what the pen is made out of, hopefully plastic, Is there enough room to insert something like a small screwdriver or chisel into the available gap which could then be used to break the pen into pieces. Then use a powerful vacuum such as the ones at a car wash to suck the broken pieces out. Sounds crazy, but as I said, I’ve done it in a similar situation. Good luck.
Old Jan 8, 2024 | 06:02 PM
Wjw's Avatar
Wjw
Sl63 amg
Nope it can’t be reached with anything but a thin piece of wire bent in a “C” shape. The flip up door on opening transitions from horizontal to vertical and the arc of forward edge hides the space until it’s nearly vertical at which point the pen is behind the door. This is my reward for picking up a free pen that I have no use for. Again
Old Jan 8, 2024 | 08:47 PM
jrupp's Avatar
2013 SL550
I am not mechanically inclined at all but was able to install Carplay in my SL. The easiest part was removing the center console panels. If this is bothering you that much I think it'd be worth looking at the step by step instructions. I think you could do it!
Old Jan 9, 2024 | 07:13 AM
JettaRed's Avatar
Veteran: Army
Try this
Old Jan 9, 2024 | 10:36 AM
Wjw's Avatar
Wjw
Sl63 amg
That’s the knowledge, but beyond my pay grade. For me it might be easier to turn the car upside down and shake it out. This will remain a lesson in restraint and peace in how it is. Unless the ballpoint fairy appears.
Old Jan 9, 2024 | 06:50 PM
JettaRed's Avatar
Veteran: Army
Well, that's an option. Kinda like this guy? (White car)
