SL/R231: Switchable 12V in door
Old Feb 11, 2024 | 02:29 PM
Heikojuerges's Avatar
2015 AMG SL63 (R231)
Hi All,
I am trying to find switchable 12v somewhere in the door of my 2015 AMG SL63.
When I am testing cables from the door control module, I can only find permanent 12v. Without the door card connected, I can’t really lock the car and measure from the inside :/
Any idea where to grab switchable 12v or the wire color?
thank you so much in advance.
Old Feb 13, 2024 | 10:17 AM
Keon's Avatar
SL550
Old Feb 14, 2024 | 01:02 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Originally Posted by Heikojuerges
Hi All,
Do you have a VIN? I can probably post the wiring diagram for the doors from the WIS. You should be careful not to overload certain circuits, depending on what you're hooking up.
Old Feb 14, 2024 | 01:19 PM
Pulled a VIN off Autotrader...
May not be an exact match but, may help.
edit: assumed its for the drivers door.
See attached PDF.
(You should be able to zoom in and rotate any part of the PDF with Adobe Acrobat.)
Good Luck
