SL/R231: Alternator fuse location? Is there one
My sl550 stalled and when I went to check the battery in the trunk the negative was loose. And when I loosened it and reseated it there was a bit of an arc and now my alternator isn’t charging.
is there a fuse just for the alternator? If so does anyone know the location?
Thank you
Post #7 lists the fault codes for B95.
