SL/R231: interior door handle no longer working
Have you had the door panel removed at any time previously? These are cable type mechanism which release the door latch.
There is a cable that is attached to the interior door handle from behind the door panel.
You’ll need to remove door panel to access it.
The cable end is attached (pushed in) to the interior handle with plastic clip from behind the door panel..
What typically happens is if the cable wasn’t properly attached from a previous repair, the cable end can work its way loose.
Sometimes though, the clip (or cable) can break which will disconnect the cable that connects the door latch. You should feel the disconnected interior handle will have less resistance and feel looser than the side that is properly attached/working.
(see circled areas in attached pictures below)
