SL/R231: Parking Assist Sensor
I have run the front of my 2015 SL400 up on curbs once too often. The front side parking assist sensors are not aimed low and front enough to trigger a warning.
So, wondering if I could purchase one or two sensors, and mount them under the nose of the car such that they will detect curbs before I hit them.
If I buy direct replacement sensors, then could I simply wire the new sensors to the existing sensors, ie, parallel wired connect?
Has anyone done this? Also, if I wire into existing sensor circuit, then I would not have to run a wire to the head unit, like if I was adding a front camera.
If I can do this, then a new sensor from CarParts is only about $33.
All comments and advice will be appreciated. Thanks, Joe
There is a method to align and calibrate the sensors, but I have never done it. My recommendation is to reach out to @BenzNinja to see what is involved.
MB has had issues with painting of those sensors, and have gone so far as to release a guideline for proper paint thickness. Variations in paint can cause the sensors to come out of "tune"
https://rts.i-car.com/crn-1875.html'
There is no adjustable alignment via XENTRY on those sensors, only proper placement in bumper and paint variation specifications.
Also make sure they are properly set in the bumper!
See attached WIS docs...
Good Luck!
Thank you for the comments and links. Very helpful!
BTW, impedance (Z) is a term used to describe opposition to current flow in AC circuitry; in DC circuitry, the term is resistance (R). Both are typically measures in units of Ohms (Ω).
