SL/R231: Stock Exhaust
Old Oct 21, 2024 | 04:47 PM
JettaRed's Avatar
Veteran: Army
Stock Exhaust
Not sure how many SL owners have been under their cars, but I thought I would share a pic of my exhaust system.
First, the pipes are huge. I should have put a caliper on them, but I'm guessing 2.75" or 3". The second thing is that there are two crossover pipes (red arrows) that help balance the exhaust pressure, reduce in-cabin drone, and increase engine output. Not bad for a stock exhaust.
Old Oct 21, 2024 | 04:48 PM
JettaRed's Avatar
Veteran: Army
Closeup of the crossover up front.
Old Oct 22, 2024 | 09:36 AM
JettaRed's Avatar
Veteran: Army
O.D. is actually 65mm or 2½". Tried to get a better look at the front "crossover" because I'm thinking it may only be for support and not an actual crossover pipe. But the car is too low to get a good look. The rear one is clearly a crossover by the way it is formed.
Old Oct 22, 2024 | 10:07 PM
toi's Avatar
toi
2014 sl550
https://www.reddit.com/r/mercedes/co...t=share_button
right one is stock for sl550. from engine towards on each pipe is cats, the resonator, h pipe 1st muffler, and 2nd muffler. thats about it.
2.5 inch on sl550 3 inches and a different setup on sl63
Old Oct 23, 2024 | 07:09 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
I put mine on a friend's lift once a year to change the oil. I'll have to check out the exhaust system next time. I also plan to change out the brake fluid at the same time.
