SL/R231: Help! Roof Flap Replacement Not Extending
Old Nov 26, 2024 | 07:47 PM
Ransomed12's Avatar
2013 SL550
Hi all:
Like some others, one of my roof flaps no longer fully retracted. I ordered a replacement set of flaps.
The replacement set of flaps came "not retracted" or closed. I could not manually extend them. However, when I pulled the old flaps off, they were extended.
I have installed everything -- the electronics are simple, there's two electronic connections. I've triple checked connections are secure.
When I go to close the top, the top will not close, the flaps remain in "closed" or not extended position.
I'm missing something obvious. Can anyone tell me what I'm doing wrong?
Old Nov 26, 2024 | 10:50 PM
Ransomed12's Avatar
2013 SL550
update. this was fixed by re-installing the old flaps, finding the point after which the flaps are closed, then swapping them in at that point.
Old Nov 27, 2024 | 12:48 PM
JettaRed's Avatar
Veteran: Army
So, it was the control module that remembered the last position?
