SL/R231: 2013 SL63 ABC front strut boot split - replace in situ?
In the health check, the Tech noted that the front ABC strut boot was split.
Given that the struts are expensive, I think it makes sense to replace the boot to keep road crap out.
I’d rather not disconnect the ABC line to completely remove the strut as its all just been serviced.
Looking at WIS, I’m wondering if its possible to replace the boot by unbolting the lower strut fixing, disconnecting the spring control arm and loosening the top strut bolts.
This should allow the old boot to be slid downwards off the strut and the new one installed by reversing the process.
Just wondered if anyone has tried this or if I’ve missed something obvious which will cause a problem?
Any comments or advice would be appreciated.
Russ
I'm sure you already know this, but might as well mention it for folks searching in the future...
Torque everything loaded and at ride height, and blue Loctite. WIS mentions some one time use fasteners involved.
I believe you should be able to sneak the dust boots in. Probably want to check the alignment after the work is complete.
Keep us posted.
Good Luck!
I was planning to only loosen the top strut fixing so I could wiggle the strut around if necessary,
Boots are available from both Merc and aftermarket so getting the parts will be no problem.
Not sure if I will need to de-pressurise the system but its easy if so.
I'll take some photos as I'm pretty sure this is a common issue.
The tip is to lower the car so the shock is fully retracted and turn off the ABC and then turn off the car. Because the fluid goes back into the reservoir once the car turns off, the shock can move. You could pull the fuse for the pump to stop that from happening. Without opening the bleed valve on the line, it is impossible to compress that shock by hand while working on it like a normal strut. I haven’t done this car, but I did fully rebuild a 220 55 abc system so got some good experience.
