SL/R231: Leaving Top Down For Extended Periods
Old Jul 23, 2025 | 10:54 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
I'm hoping to get some advice on whether leaving the top down for extended periods (weeks/months) will cause any issues.
I rarely drive with the top up, so thinking it may preserve the top mechanism by not cycling so much.
The car is garaged with a cover.
Thanks!
Old Jul 23, 2025 | 11:21 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
I do the same thing. So, my thoughts exactly. I leave my top down for extended periods as well. If I drive it, I take it out of the garage with the top down, drive with it down, and if I can park it where I can keep an eye on it, and weather permits, I park it with the top down. I like what 1 of our forum members referred to it as, “infinite headroom”. As a mechanical system, limiting use limits wear and tear. The only thing I worry about is over time, the top getting “frozen in position” so to speak. Every so often mechanisms need to be exercised so to speak, to circulate lubrication and whatever pumps are involved. I don’t know if I answered your question but hopefully my thoughts helped.
Old Jul 23, 2025 | 01:33 PM
Thanks for your reply.
That's exactly what I wanted to hear. The car sits for 6 months so, like you, I'll do an open/close sequence every once and awhile. I also leave the doors and hood open a crack. All-in-all I'm thinking it's good for the rubber seals so that they're not compressed all the time.
I just heard back from my service advisor; he agrees with you that leaving the dop down is not an issue.
Old Jul 24, 2025 | 10:13 AM
fun33's Avatar
2017 550SL - 2018 560S
The biggest single problem with leaving the top down for an extended period is the increased possibility of getting rats inside the vehicle. Almost any garage will attract rats, especially in the winter. A cover will help, but it will not prevent rats from using your interior as a nest.
Old Jul 24, 2025 | 10:31 AM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
Moving parts need to move - important to exercise it here and there I would say. Also important to extend the roll bar now and again to keep those parts from seizing up.
Old Jul 25, 2025 | 07:38 AM
Bill Julyan's Avatar
Veteran: Navy
2019 Mercedes SL 550, 2022 Infiniti QX80
Oh great. That's a problem I never thought to worry about. Paint flakes from the garage ceiling, bird crap from the occasional bird flying in through the garage door, pollen in the spring, but I never thought about rats.
Old Jul 26, 2025 | 05:30 PM
C280 Sport's Avatar
MB’s of all kinds.
Leaving the top down or up for extended periods of time is never an issue for hard tops. The mechanisms will not be bothered. A huge advantage of hard tops vs rag tops where you have to be mindful of how long you keep them up or down due to creasing and premature wear and tear. Just make sure no animals of rodents get inside the car. Even in a brand new garage that is finished off with epoxy floors like I have you can still get animals! Amazing how they find a way in!
Old Jul 26, 2025 | 08:56 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
So, what is the best solution? Rat poison around each tire?
Old Jul 27, 2025 | 07:12 AM
rfb3's Avatar
SL550
Get a cat
Old Jul 27, 2025 | 09:20 PM
Kalepsis's Avatar
2017 SL450
Originally Posted by rfb3
Get a cat
This is the way.
But, on the other hand, if I had a cat who has access to my garage, I would definitely not leave the top down on the SL.
Old Aug 1, 2025 | 04:55 PM
sjmohr's Avatar
2014 SL 550 Sport Package
The roll bar cannot be manually deployed in the R231 to my knowledge.
Old Aug 4, 2025 | 05:27 AM
ThatsMyDawg's Avatar
SL 400
Correct.
The R231 has roll bars that deploy rapidly in a flip over, but can also deploy if say you go over a hilled train track too aggressively and get a little bit of air while the top is down. Everyone I have read that had their bars deploy had to go to the dealer to have them reset and lowered after deployment, however I’m sure some diy people would take a crack at it.
If your car won’t go into park simply open the drivers door with the car running and it will auto go into park. Until you are able to fix the issue that feature will have you covered and you will never be stuck in drive.
Best wishes.
Old Aug 9, 2025 | 10:37 AM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
Back in the 70's or 80's Road & Track did a quarter mile road test of a gasoline powered pogo stick. Two advantages the article mentioned were that the pogo stick offered "infinite headroom" and it "turned on a dime." They also tested a Goodyear blimp and a Porsche 911S which offered "Performance of an American super car without the stigma of low cost."
