SL/R231: Another newbie question...Blind Spot Inoperative
Old Aug 14, 2025 | 11:26 PM
Turbosnake's Avatar
2013 SL550
So the blind spot system is showing inoperative... I went into the setting to try to just deactivate it and I can seem to be able... thoughts??
I just am trying to turn in off so I don't get the warning every time I start the car.
Thanks again
Old Aug 16, 2025 | 09:56 AM
RA1126's Avatar
Check your driver and side view mirrors. When starting the car observe the red to amber indicator on each mirror. You'll probably have to start it to observe each mirror because the change is like milliseconds. I wrote a detailed post on another forum about this. I had to replace the passenger side mirror on my 2013 SL550. The indicator should go from red to amber upon startup. If I recall, the indicator stayed red. I worked oil field in Texas for almost ten years and was able to borrow a Snap-On analyzer from a mechanic and it displayed: Fault in passenger side door module or a short or open circuit between door module and mirror. It narrowed it down to which side anyway. I chanced it and bought a mirror for $127.00. There's a small circuit board on the backside of the mirror. Easy enough to change. Let us know what you find, good luck.
Thorgod
