SL/R231: ABC filter and flush gone WRONG! Need Advice
Old Sep 10, 2025 | 09:53 PM
ryanholi0's Avatar
2x 2013 r231 SL550
I was attempting a flush on my 2013 r231 with 106K miles and I believe got air in the system while changing the filter and pouring in CHF 11s. The car is in the lowest possible position and it will not pump back up. and is give the ABC Failure/Stop Car error. The fluid level is good but it won't prime any fluid to fill the shock.
I am going to try and raise the car up and get it off its wheels to allow the shocks to expand and see if this helps but any advice would be super helpful. I'm totally bummed and appreciate your time.
Thanks,
Ryan
Old Sep 11, 2025 | 05:13 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Thanks,
Ryan
you need to put a little bit of pressure in the fluid reservoir. You could use a bike pump or anything just to get some PSI in there.. @10max. while you’re putting pressure on the reservoir have somebody press the up-and-down button. Or put the pressure in right before you start it. But make sure to not over pressurize the tank with a compressor that gives constant airflow. This only takes about 30 seconds or so and should get you fixed up.
Old Sep 11, 2025 | 04:02 PM
ryanholi0's Avatar
2x 2013 r231 SL550
OMG! You are a SAVIOR! This did the trick! I used one of those battery tire inflators and was able to seal it with a a cone bleeder attachment got it up to 10psi and had my wife crank the car and it started lifting and making some noise and came alive again!
THANK YOU THANK YOU THANK YOU!!!!
Old Sep 11, 2025 | 04:15 PM
Baltistyle's Avatar
glad you got it working.
