SL/R231: Dumb Question?
Old Nov 23, 2025 | 08:46 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
Dumb Question?
Is there a way to dim the instrument panel and Nav screen when driving at night?
Old Nov 24, 2025 | 07:12 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
On my 2019 450, there's a small, round shaft protruding directly under the speedometer that controls the brightness of the instrument panel and the Multimedia display. The map can also be switched to "night mode" via the map menu options.
If I remember correctly, the control under the speedo controls the ambient lighting as well.
Old Nov 24, 2025 | 08:31 AM
rmorin49's Avatar
Veteran: Army
Thanks. I'll see if my 2015 has this knob.
Old Nov 24, 2025 | 11:28 AM
GTIBlack's Avatar
Mercedes SL R231
As ​​​@hornethandler mentioned, there is a small knob that is obscured by the turn signal stalk, where you can adjust the instrument cluster brightness.
I am not sure it affects the COMAND display. For that, there are adjustments in the settings.
Additionally, you can set any number of features to activate by touching the Favorites button (Star button next to the shifter). If, for example, you want to activate the massage feature or display off/on feature, you assigned the Star button to the feature you want. The list of Favorites is found in the System settings.
List of Favorites — scroll down for more.
The selected Favorite is activated by pressing the Star button.
Old Nov 24, 2025 | 03:09 PM
rmorin49's Avatar
Veteran: Army
Good info. Thanks. 8 should read the owners manual, DUH.
Old Nov 27, 2025 | 02:35 PM
rmorin49's Avatar
Veteran: Army
Found the knob. Happy Thanksgiving.
