SL/R231: Driver’s door lock button marred
Old Jan 6, 2026 | 12:37 PM
docsout's Avatar
2023 S Class 2013 SL
https://a.co/d/imvlUjL
2013 R231 drivers door lock button marred. Does a shop need to remove the door panel? Or, is this something that a layperson could do as described in the site’s installation guide?
Old Jan 6, 2026 | 01:16 PM
JayHall0315's Avatar
2017 SL550, 2025 GLA 250 (Wife), 2010 Accord ELX, and 1968 Camaro SS
A lay person can do it and you will not need to disassemble your door. You can use a pick to gently pry out the old button and snap in a new replacement. Make sure to pry from the inside and not from an outer angle where you risk making a tension mark. I would use thick, clear, packing tape as a layer of protection around the edges. One pick, three minutes, and brand new replacement buttons are all that is needed. While I did not detail the driver's door lock button specifically, you can see the general method in page three of this thread where my son encountered a similar problem:
https://mbworld.org/forums/sl-class-...estions-3.html
Old Jan 10, 2026 | 06:06 AM
docsout's Avatar
Jay, thanks for the advice/response. I'll try it.
