SL/R231: Air pump in trunk cycles every few seconds, normal or not?
Old Mar 29, 2026 | 12:43 PM
txturbos600's Avatar
R231 SL63
I have an SL63 and noticed that the air pump in the trunk is cycling and venting every few seconds with the key on. I am not sure if this is normal or not.
If I put my finger over the exhaust line of the pump, it stops. When I remove my finger, it starts after a couple of min.
I have no errors or malfunctions that I am aware of.
File Type: mov
Old Mar 29, 2026 | 06:48 PM
PotatoHeadII's Avatar
Nope. Not normal. You have a leak somewhere.
Old Mar 30, 2026 | 05:21 AM
Montreal300's Avatar
SL 550 (2014) Kia Sorento (2016)
Not normal. You have a leak sowhere so disconnect the pump until you get the leak fixed to avoid a burned out pump. Faults are not i ndictated anywhere even with a good scanner. You may be able to track the leak with a smoke test.
Old Mar 30, 2026 | 07:31 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Definitely a leak. Probably not the seat bladders since they would be shut off normally.
On my 2014 the hose fittings at the pump were leaking. Another possibility is the reservoir next to the pump.
Old Mar 31, 2026 | 08:41 PM
westy1595's Avatar
2014 SL550
I had the same situation and my tech found that the brain/computer running the pump lost it. He reprogrammed it and all is fine, seats, etc.
