SL/R231: Decoding The ASSYST PLUS Sub-Codes/Service Items
Old Apr 16, 2026 | 09:39 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
Does anyone know what the “ASSYST PLUS Sub-Codes (Service Items) are for the 2019 SL450?
The Service Items codes are displayed in the instrument cluster when you are in the ASSYST PLUS menu to advise what services are due.
I searched and found the following on the internet, and although it looks legit, I’m hoping the experts here will verify.
Service codes for the Mercedes-Benz R231 SL-Class (2012–2020) are managed by the ASSYST PLUS system, which indicates when maintenance is due. These codes are generally divided into Service A (minor) and Service B (major), further detailed by sub-codes (0–9) that specify which components need attention.
Here is a breakdown of the common service codes and items for the R231:
1. Main Service Intervals
  • Service A (Minor Service): Usually due first, followed by every 20,000 miles or 2 years.
  • Service B (Major Service): Typically due at 20,000 miles or 1 year after the previous service, then every 20,000 miles/2 years.
2. ASSYST PLUS Sub-Codes (Service Items)
When checking the "Full Service" menu in the instrument cluster, you may see numbers 1–20. For the R231, these often correspond to:
  • Service 1: Minor Basic Service (Service A)
  • Service 2: Major Basic Service (Service B)
  • Service 3: Engine Oil and Filter Change
  • Service 4: Brake Fluid Exchange
  • Service 5: Combination Filter
  • Service 8: Air Filter
  • Service 11: Fuel Filter
  • Service 12: Spark Plugs
  • Service 13: Coolant Flush
  • Service 20: Automatic Transmission Oil and Filter
3. Common R231
  • Service Combinations (Examples)
  • A0 / 505: Basic Service A (Oil + Filter + Inspection).
  • A1 / D0D: Service A + Combination Filter.
  • A4 / D50J: Service A + Spark Plugs (common on high-performance models).
  • A7 / G50M: Service A + Brake Fluid Service.
  • B0 / 1607: Basic Service B.
  • B4 / B60H: Service B + Spark Plugs.
  • B7 / G60N: Service B + Brake Fluid Service.
4. R231 Specific Maintenance Items
Given the features of the R231 SL-Class, the following are often included in these codes:
  • Active Body Control (ABC) / Suspension Check: Checked during Service B.
  • Panoramic Roof Service: Lubrication and cleaning (Service 10).
  • V-Belt Inspection: Part of the Service B check.
To find the exact service required for your specific R231, you should access the ASSYST PLUS menu in your instrument cluster to get the exact Workshop Code and Service Code “.
Old Apr 17, 2026 | 08:44 AM
PotatoHeadII's Avatar
Interesting. I’ve never had any codes show up.
Old Apr 17, 2026 | 08:51 AM
You have to be in the ASSYST PLUS menu.
Here's the instructions on how to access the menu, and to read and reset the codes.
