SL-Class (R232) Discussion on the 2022 R232
SL/R232: Took delivery today and need some help.
Old Aug 29, 2022 | 09:18 AM
iridium18's Avatar
2023 AMG GLE63s, 2017 AMG SL63, 2024 Sprinter, 1958 Chevrolet Corvette
Sharp looking combo - Congrats !
Old Aug 30, 2022 | 09:44 AM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
Originally Posted by Tifoso48
BTW - discovered today that the 12v socket can't be used for the trickle charger. It can only be used for --- outgoing current.
The trickle charger must once again be hooked up to a +/- terminals in the engine compartment.
That clearly is a step back from the GT which has a 12v in the trunk that can be used for incoming and outgoing.
I would guess the battery(s) is in the trunk area under the right side panel for weight distribution reasons.
Old Aug 30, 2022 | 10:15 AM
Tifoso48's Avatar
2022 AMG SL63, 2015 Ferrari 458 Spyder, 2021 ALPINA B7
Yes, there is a battery in the trunk under the "cover" However, the place to put the trickle charger is in the front on the passenger side - you need to lift a small plastic cover for the + and there is "short exposed pole" for the ---.
