SL-Class (R232) Discussion on the 2022 R232
SL/R232: CarPlay problems solved!!!
Old Aug 30, 2023 | 05:29 PM
e350wagon1's Avatar
2011 e350 wagon
I had continuous problems w CarPlay. About half the time it either wouldn’t connect („waiting for CarPlay“) or disconnect during play, etc etc
Fix is I deleted the phone, bought an wireless CarPlay adaptor on Amazon WQQBFF ($59) connect to USB-C under the armrest and the device shows up as a phone.
Connected my iPhone to that and since then PERFECT and connects really fast.
Old Aug 30, 2023 | 07:51 PM
California John's Avatar
2022 AMG SL63
An interesting solution. There is a bulletin about the connectivity problems which my service advisor showed me. The bulletin says that it is usually caused by being close to an area that is giving out a strong wireless signal....like construction zones on the highway - that sort of thing. And that is usually when I get disconnected....going by a large road construction site near me. I can predict it. Good to see you've found a solution. The service advisor gave me a copy of the bulletin. I just ordered the same device!
Old Aug 30, 2023 | 08:01 PM
e350wagon1's Avatar
2011 e350 wagon
I had that same drop daily on 101. Same location.
That’s gone now👍
Don’t forget to delete your phone from the car when you use the dongle…
Old Sep 13, 2023 | 12:19 AM
2022 AMG SL63
I am returning my adaptor. Not as many connectivity problems but sometimes It doesn't want to connect at all - and will still disconnect sometimes....not as bad as the original system - but almost now.
Old Apr 8, 2025 | 07:23 PM
khiroshima's Avatar
2023 SL63 + 2021 Cayenne e-hybrid
Thank you, will give this a try, CarPlay seems to drop regularly (for me, high signal areas and especially by the airport), getting really annoying, will give this a try! KH
Old Apr 13, 2025 | 06:13 PM
khiroshima's Avatar
UPDATE: I had ann old Ottocast wireless CarPlay adaptor that I used with a previous (wired CarPlay only vehicle) and had great results in my SL 63. No more glitches by the airport, kinda lame that this cheap adapter is better than the Mercedes integrated system, but I wasn’t using the second USB-C in the armrest compartment anyway, so no harm. Here’s the link to the adaptor I’m using: https://a.co/d/6U4456c
