SL/R232: Disable proximity autounlock
id like to disable the feature where the car unlocks as I approach and only unlock when I touch the handle. Is this possible?
If you want to disable keyless go you can, then the handles wont pop out when it senses the key nearby. You double press the lock button until you see a constant light for a second. Pressing any key will re-enable keyless go.
any tips on how to do so?
Link to the section in your owner's manual:
https://www.mbusa.com/en/owners/manu...ion-of-the-key
I wonder if OP should just toss the key in a faraday pouch and then unlock and lock the car via Mercedes Me Connect and call it a day, or OP can just remove the battery and then unlock the car with the app (although this is more risky because then if the app doesn't work, OP can't get in the car).
Once the disabled key is inside the vehicle (after unlocking from the app), just place the key at the marked spot and start engine like how a dead battery key is stored. Although there is a risk of forgetting to bring the key with you when you do that.
