SL-Class (R232) Discussion on the 2022 R232
SL/R232: Front tyres scrubbing
Old Dec 5, 2024 | 05:52 AM
Graeme369's Avatar
SL55 r232
My 23 r232 scrubs its front tyres horrendously when manoeuvring at slow speed. My dealer says this is normal! Anybody have the same experience? Thanks
Old Dec 5, 2024 | 01:58 PM
khiroshima's Avatar
2023 SL63 + 2021 Cayenne e-hybrid
ZERO rubbing - they are crazy
Old Dec 5, 2024 | 06:53 PM
wem's Avatar
wem
‘24 Maserati GranTurismo Trofeo;'22 AMG SL55;'23 Porsche Cayenne S Coupe;'13 Porsche Boxster S
If the weather is cold, it is probably the summer tires making noise when turning. This is normal due to the rubber compound hardening below 45 degrees F (7 C).
Old Dec 5, 2024 | 08:46 PM
California John's Avatar
2022 AMG SL63
Are you sure you are not hearing the Ackermann effect along with the rear wheel steering? When I pull out of my driveway and slowly crank the wheel to full lock to get into the street the tires are indeed scrubbing (judder) a bit (not on the fenders mind you) and then as the steering wheel in slowly straightened the scrubbing goes away. Normal.
Old Dec 6, 2024 | 02:41 AM
Graeme369's Avatar
SL55 r232
I’ve lived here all my life and owned a number of nice cars and never experienced this!
Old Dec 6, 2024 | 02:43 AM
Graeme369's Avatar
SL55 r232
it’s definitely the front scrubbing on the road surface, so badly I feel it through the steering wheel, like the car wants to go straight ahead. There is also a clunk on full lock coming from
the front end. I’m going to get the front alignment checked.
Old Dec 6, 2024 | 08:23 AM
W205C43PFL's Avatar
So it is basically the crabbing effect?
Old Dec 6, 2024 | 08:29 AM
Graeme369's Avatar
SL55 r232
yes!
Old Dec 6, 2024 | 08:54 AM
W205C43PFL's Avatar
yes!
I see, ya that is very common with non winter tires in the cold.
Old Dec 6, 2024 | 10:17 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Normal, at least that’s what my salesman told me. When the tires are cold, I try to avoid turning the wheels anywhere close to the stops. I will instead, make a 3 point turn into a 4 or 5 point turn, just to avoid the tire hopping/clunking.
Old Dec 6, 2024 | 10:54 AM
mr.rpm's Avatar
SLS
100% the Ackerman effect….normal for high performance summer tires below a certain temperature
Old Dec 7, 2024 | 03:14 AM
Graeme369's Avatar
SL55 r232
had many “ high performance “ tyres in my many years of car ownership and NEVER experienced anything like this. Some of those cars where also AWD. I don’t accept that this is normal. I’ll get it checked.
Old Dec 7, 2024 | 12:35 PM
mr.rpm's Avatar
SLS
I too have had many many through the years and only experienced this for the first time on a Porsche GT3 RS few years ago then on many others after that. I suspect this has only started to become more noticeable with more modern rubber compounds. It does feel odd the first couple times it happens but you will eventually find out what we are telling you is correct unless you have someone that doesn’t know what they are doing advise you and start messing with your alignment or sell you some new tires you don’t need. I’m assuming this only happens when it’s fairly cold out and you are turning the front wheels tightly at full lock or almost full lock at very low speed, right?
Old Dec 7, 2024 | 12:37 PM
Graeme369's Avatar
SL55 r232
it’s slow speed parking manoeuvres at all temperatures. I am going to get the alignment checked against MB settings just to be sure, but I have no intention of messing with the car.
the tyres on the car are Michelin PS4S. I’ve never had them before but have read so many great reviews. Will be interesting to see how long they last.
Old Dec 8, 2024 | 04:10 AM
Graeme369's Avatar
SL55 r232
crabbing scrubbing its the same!!
Old Dec 8, 2024 | 05:18 AM
W205C43PFL's Avatar
I see.
Old Dec 8, 2024 | 10:25 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
It’s not just AWD. It’s also 4WS. The 4 wheel steering is probably more responsible for the tire hop/crab scrubbing/turn clunking, than the AWD. But both of them together are the root cause.
Old Dec 9, 2024 | 12:01 AM
2022 AMG SL63
Definitely. The rear wheels turn to opposite angle to help the front get around and that accentuates the angle - hence the scrub/judder etc. It just accentuates the Ackermann effect of the front wheels at different angles as the car turns.
