SL-Class (R232) Discussion on the 2022 R232
SL/R232: (Help) 2015 Sl550 Oil pump solenoid
Old Sep 19, 2025 | 05:36 PM
blacklybenz's Avatar
2015 Sl550
I was attempting to unplug my oil solenoid and pulled it out. I could not get it back in. I believe it is broke. Can someone help me with a part number for a new one? There is a hole where the connector was, but it does not leak while the engine is idling. Please help with
suggestions. Thank you
Old Sep 19, 2025 | 07:04 PM
2015 Sl550
it is leaking. Not sitting still, But when you move, it leaks.
Old Sep 19, 2025 | 08:11 PM
2015 Sl550
okay. The plan is to buy a new connector with an o-ring and to install. Worst case, the connector will need to be cut short. Whatcha say? It is already unplugged and I didn't plan on plugging it back up. I guess the oil pan has to be removed to fix correctly. Cheap plastic. I thought that was a BMW thing!
Old Sep 20, 2025 | 12:23 PM
2015 Sl550
I am an idiot. If you ever find yourself in a similar situation, just go and get your a rubber plug with a taper. Problem solved. TY
Old Sep 22, 2025 | 10:29 PM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
Sorry no one replied to your thread.
I am not so sure it is posted in the proper forum.
R232 is SL43 SL55 SL63.
If you posted in the R230 forum, you might get some guys there who would be knowledgeable.
Sorry, R231 forum
Last edited by MB2timer; Sep 23, 2025 at 10:01 AM. Reason: Correction for forum name
Old Sep 23, 2025 | 07:33 AM
TinManMike's Avatar
2014 SL 550 R231; 2019 GLC 43 AMG X253 ; 2013 CLS 550 C218
Post this in the R231 forum.
The 2015 SL550 is a R231, not R232.
Wish I was more help.
