SL-Class (R232) Discussion on the 2022 R232
SL/R232: Key fob closing of roof and windows
Old Today | 04:16 PM
SL 63's Avatar
2022 AMG SL 63
Hello !
I can’t seem to find a setting that will close the windows when you close the roof with the key fob.
Anyone know if this is something that can be enabled?
It pretty much negates the convenience of using the key fob to close the roof then have to get into the car to hit the start button to close the windows.
It’s much more comfortable to exit the car with the roof retracted and also empty the contents of the back seat like groceries, golf clubs etc.. It seems like it would be natural setting but I cannot find a way to enable it.
thanks !
Old Today | 05:09 PM
superswiss's Avatar
2019 C63CS
I don't believe there's a setting as far as I know, but from the description it sounds like the soft top closes first and only once it is closed, it closes the windows, so make sure you keep holding the button and not let go after the soft top is closed. It could also be possible that you may have to let go of the button once the soft top is closed, and then press and hold it again to close the windows.
Old Today | 08:22 PM
Dunga's Avatar
'23 SL63 AMG, '24 Range Rover SE P400, ‘26 Corvette Z06, ‘25 Audi RS7 Performance
Op are you in the US? If so I believe it’s because of local safety regulations the feature is disabled unlike in European cars. Not sure if there’s a way to unlock the feature like you can with the laser matrix lights.
