SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: hard top
Old May 5, 2005 | 03:12 AM
makhan singh's Avatar
420sl 1989
hard top
hi, guys need help taking off the hard top roof, any help would be appreciated 107 model. regards makhan singh
Old May 5, 2005 | 10:11 PM
nobby's Avatar
1983 280sl euro
First Makhan, you should find a minimum of 1 friend to help and two if you have problems with the rear latch........
Old May 11, 2005 | 04:25 PM
abe g's Avatar
hard top removal
First release 2 front latches, 2 side latches, thenrelease side laches behind drivers side (2) upward) have someone go into car and (use head) to lift rear as much as you can, a wood shim under lid will help) \ Use small screwdrive to push latch to passenger side to release hold down hook (latch). When roof off, chek cable to latch (small lever) work it back and forth and see if it effects latch release. You can adjust cabe (tricky) with slide hold down to take up slack so that small lever unlkatches hook. Hope this helps, let me know. good luck Abe G
Old May 13, 2005 | 11:53 AM
420sl 1989
thaks guys got the top off now the problem of storing wife not talking as the hardtop is in the bedroom
Old May 14, 2005 | 12:40 AM
nobby's Avatar
1983 280sl euro
Smile Hardtop
Hey, maybe it could be used as a prop.......
