SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Name that part.....?
Old Sep 26, 2005 | 09:18 AM
homeline's Avatar
After removing the glove box liner in my '86 300SL to check and see if a mouse did any damage, I noticed a hose under the dash that has deteriorated due to age. It's made of three separate pieces. The two ends are a rubber hose about 5/8" IAD and make a couple bends. One end attaches somewhere to the firewall and the other end to (I believe) the center dash vents. The center section that connects the two ends is (was) made from a foam-type filter that's about 1-1/8"OAD & 3/8"IAD. It has disintegrated into a greasy mess. My questions are; 1: What does it do? and 2: Can I replace damaged section with a piece of vinyl or rubber tubing?
