SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Brake bleeding on 560 SL???
Old Jun 26, 2006 | 08:31 PM
sidewindersteve's Avatar
Having trouble bleeding brakes on 1987 560 SL-- Hard braking caused loss of fliud. Master cyl was leaking on booster and I replaced the m/c after bench bleeding. Rear brakes will not bleed (it has ABS). Tried disconnecting battery cable and using Mighty Vac brake bleeder, no results. Tried it with someone pumping pedal and bleeding conventional way with -cable unhooked--my confidence is dwindling. Does it need to be power bled or pulse ABS unit? Does anyone have any ideas for me? this is my wife's car and she wants to drive it while summer is still here!
