SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 1982 R107 Sl No Start Help!
Old Aug 22, 2006 | 01:36 PM
toolztud's Avatar
Hello, I have a 1982 R107 It has been in a body shop for three weeks. (cosmetic repairs only, no collision) Upon going to pick the car up yesterday, they told me the car will not start. The engine is turning quickly, but is not firing. Bright headlights, all accessories function. What is the diagnostic path and what are likely culprits? The previous owner stated that the car had the same failure and they replaced the control unit. I mention this on the off chance that some other component or system is causing the failure?
Any thoughts or help would be appreciated.
Old Sep 20, 2006 | 06:52 AM
Bill Reid's Avatar
NONE Starting
Have you tryed looking at the fule pump relay under the cover by the drives side feet
its about the size of a cigarette packet it also works the kick down
its marked KICK ,Take it out and give it a few tapes with something and put it back swich on the ignition and see if you here the fule pump prim the system a werring nose from tht rear of the car
you can take the cover of the relay and check the soldered joints
where the circuit board meet the pins they crack over time a good going over with a soldering iron and there ok
