SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Any detailed writeup on fixing the "heater box" issue and what exactly is wrong?
Old Apr 29, 2007 | 11:00 PM
2quik6's Avatar
1987 560SL
I've read that if the 2 center vents do not blow AC on the 560SL that it indicates a heat box issue. Mine center 2 do not blow.
What exactly is the issue that needs to be fixed?
Does the heater not work when there's this issue? Step duaghter has the car so I can't go out and try it at the moment.
Any writeups on how to fix it? I know you have to take most of the under dash apart, nothing I can't handle if there's some sort of write up on it.
Old May 6, 2007 | 08:58 PM
Ears's Avatar
1988 560SL
I welcome you to http://users.adelphia.net/~rmsmithco and follow the links. You can get an idea from my experiences (and others reported) there. Also, follow the links to benzworld.org and mercedesshop.com for more info.
good luck.
