SL/R107: Getting the right documentation
I have purchased an '87 560SL with 58K miles. Clean, but a few problems to deal with, one of which is AC and the other is vent controls.
1. The system is low on R-12. What is the recommended replacement for this
refrigerant? I heard you can't use R-134. True?
2. Before I get into the vacuum actuator etc, I want to get the right manuals.
Who makes the best set of manuals? Are they available in CD?
Thanks and best regards.
Michael
Use R12 in your AC system. Other poster is correct that changing to R134 is a bad idea. You lose cooling efficiency, the compressors were designed to run R12, etc. If a local AC shop tries to talk you into converting, find another shop.
Manuals on CD at www.mbusa.com for $20 +/- ; look under the 'Classic' link. Also, register your car while you're there. Paper manuals come up every so often on ebay and are quite pricey. Avoid Chiltons or Haynes....trash.
Have fun with the car.
Bob
Bob
