SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Drive Shaft Flex Disc - Transmission
Old Oct 10, 2009 | 11:40 AM
dhuey1972's Avatar
1987 560 SL
I was having some trouble with my transmission shifting correctly so I took it to my Indy repairmen to have it fully serviced. (Transmission) Anyway, the shifting does not seem to be any better, I can take it high up into RPM's in each grear and it will somtimes shift but often I have to switch to nuetral then back into drive for it to forward into the higher gear. The guy said I also needed a drive shaft flex disc, is that going to make any difference?
Old Nov 5, 2009 | 10:30 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The flex disc won't make any difference in your shifting, but here's what can happen if you don't replace one that is cracking: http://www.benzworld.org/forums/r-c1...disc-info.html
Old Mar 30, 2010 | 11:35 PM
dmralph's Avatar
78 450 SL Mercedes
78 450 sl
my 450 will shift fine at 25 mph then at 45 but when I'm running at 60 mph it sounds like it's just screaming... although the rpms are only 3000... it just seems like it is wanting to shift into overdrive... is their a vacuum problem???
