SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Hard top removal
Old May 3, 2003 | 11:41 AM
alanhamm's Avatar
300D and 560 SL
Hard top removal
I have an '89 560 SL and am having trouble getting the rear pin connection to the hard top to release. I have only taken this thing on and off a couple times but this time I just cannot get it off.
It loosens, but does not release completely. Any tricks?
Alan Hamm
Old May 4, 2003 | 07:59 AM
tern's Avatar
W124 230TE R107 280 SL
Alan, the release is a two function contraption, one to engage and one to tension. Sometimes the first position >engage< snags on the roof as you lift it off. The trick is to push down on the rear edge while some-one else operates the spring release. Once you have the roof off make sure the hook is going its full travel. the little spring clip on the cable outer end sometimes breaks or pops out. Derek. Edinburgh.
