SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 1985 380SL
Old Aug 15, 2012 | 08:45 PM
jjdavey's Avatar
1985 mercedes sl380
Red face 1985 380SL
Does anyone know how to get into the trunk of this car without the key? Is there a trunk opener anywhere in the vehicle?
Thank You
Old Aug 15, 2012 | 10:53 PM
abiby's Avatar
82 380SL 96 SL500
Short answer is no. Entry usually will require drilling a small hole in the trunk lid.
Lots of ifs, however. You've really not given a lot of information about your problem.
Old Aug 15, 2012 | 11:23 PM
jjdavey's Avatar
1985 mercedes sl380
Mercedes 380 sl "trunk entry problem"
Thanks for the reply, where would I put the hole so I can open the trunk? ( we don't have a key for the trunk)
Thanks ,
JJ
Old Aug 16, 2012 | 08:29 PM
abiby's Avatar
82 380SL 96 SL500
You'll need to search here or perhaps the 107 forum at benzworld.org for where to drill the hole.
However, I'm assuming you have an ignition key. Look at the attached pdf file to identify the type of key you have. If it's a master key and it won't open the trunk, then drilling the hole will probably be necessary. If you have a valet key, you should contact your dealer with vin and proof of ownership and let them order you a master key which will also open the trunk. If the locks have been changed, the new key won't work however.
File Type: pdf
Old Sep 26, 2012 | 11:30 PM
roadster Kev's Avatar
1985 380 sl
Lost key
Please ... just go to the dealer with your ownership.
