SL/R107: Low beam lamp inop, works on high beam.
If I turn on the high beam, low beam lamp illuminates. If I drive around with high beams on for a decent period of time, (20 mins) then go back to low beams. The low will start working. Fuse seems good. (#19)
Is there a relay somewhere that may be sticking?
*1982 500 SL
You probably have a bad ground or a bad headlight or dirty connector or something.
I drive in the day with them all on ... cuz that's the kind of guy I am .
I want to get those super bright blue ones but I'm afraid it would be too bright to screw around like I do.
