SL/R107: 380 SL front frame rust
New owner 380SL Found extensive rust both sides very front of frame.
Any ideas where to locate used part?
Thanks for the help, I'm told common problem
Same issue
I have the same repair undergoing.
Was the parts you buy new or used. I cant reqognize the frame in in the parts catalog (EPC), or more precicly, that the frame could be bought seperatly from the wheel whell.
Any pictures
Any pictures
bought a used front frame clip for $500.00 it wasn't a SL I think most "107" frames will work.
Only needed front 12". Shop was able to cut out and re-weld with only removing radiator.
