SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Rear shock bolt stripped...EZ fix?
Old Apr 27, 2014 | 02:19 AM
artificer's Avatar
1981 W107 500SL
Hi:
I just replaced all 4 shocks on my R107, about a 40 minute job.
Shocks that came off were branded Midas so it looks like our Midas friends rattle gunned on the old nuts & as a consequence stripped one of the bottom rear shock mounting bolt threads in the aluminum swing arm. The other bolt is stretched & should be replaced. So they did a number.
Now I can fix this a number of ways other than original, but any suggestions from those who have done this before would be much appreciated & I really do not want to remove the swing arm/s.
FIXED EASILY used a thread chaser & refitted with a thick washer under the nut/s. Thanks, John.
Old Apr 28, 2014 | 12:45 PM
artificer's Avatar
1981 W107 500SL
FIXED EASILY used a thread chaser 10x1.5 & refitted with a thick washer under the nut/s. Thanks, John.
