SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 450sl control pressure? Wur issue?
Old Mar 8, 2016 | 02:29 PM
Canaan116's Avatar
450sl
Hey everyone. New to the forum. Any help here would be appreciated. So basically I've done my pressure testing and system pressure is around 67psi. Control pressures I made adjustment and got in order. I have could pressure on a 65 degree day at about 1.5 bar and warm pressure around 3.5 bar. No matter what adjustment I make my problem is that the car won't rev much past 3k rpm. My question is how much is the vacumm diaphragm supposed to enrichen fuel. Should control pressure drop significantly when engine is revved? Could it be clogged return line not allowing enough fuel to pass back to tank? 79 450sl cis pressure test
