SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: shifter replacement
Old Jun 25, 2016 | 09:42 AM
jimbo409's Avatar
2004 sl
shifter replacement
I have a 1988 560 sl and want to replace the shifter knob,are there any videos to explain how to do this.
also where can I obtain a factory shop manual for the r107,ebay just has cds.thanks Jimbo
Old Jun 25, 2016 | 12:42 PM
myway's Avatar
450SL
On line manual http://www.startekinfo.com/StarTek/o...tedDocId=11883 Basically the same as the CD. Paper manuals do show up occasionally on EBay. For the 560SL there is the manual and a separate supplement. You need both.
The shifter knob is molded to the shaft. You would have to cut it off.
To remove shaft and knob:
Remove ash tray.
Remove ash tray frame. This requires removing two phillips head screws, tilt out from the right side then unplug the wires on the left.
Remove the wood surround by removing the two screws at the front and sliding back. When I have done this the mirror switch has popped up in the front making it fairly easy to remove and unplug. Lift the rear of the wood piece and unplug the other switches. The manual leaves out the step of sliding to the rear. It just says to lift it. This results in breaking the pin on the rear.
Once wood is removed remove the bolts on the plastic piece and lift it up on the shaft. There is a lock nut where the shaft screws in. Loosen it and unscrew the shaft and knob.
