SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Fuel Pump
Old Feb 26, 2017 | 09:19 AM
gcarra1's Avatar
1980 Mercedes 450 SL
Fuel Pump
I have a 1980 450 SL with 66000 miles with I believe to be a fuel pump issue. When I turn on the key the fuel pump starts and stop as normal and the car starts right up and runs normally. The concern I have is while Driving I hear a humming which sounds like the fuel pump is running continuously. I have gotten under the car while idling to confirm it is the fuel pump. Is this normal and the fuel pump is loud and needs replacing or is there some type of pressure switch which should be controlling the on and off of fuel pump as needed.
Old Feb 27, 2017 | 09:24 AM
myway's Avatar
450SL
It is normal. Pressure is controlled at the fuel distributor. Any fuel not needed is returned to the tank.
