SL/R107: Brake pedal return
Brake pedal return
I have an '87 560 SL and last year had a complete brake job done, Recently I went to drive the car when I notice the brake pedal didn't return to the up position when I let up on the pedal and shortly afterwards I started hearing a hissing sound like air coming out of a hose. Is this some kind of vacuum leak? Any ideas or suggestions?
I checked the economy gauge and it read zero or economy, when I would rev up the engine it would make a slight movement and then settle back to a zero level.
As it turned out the brake pedal returned on its own after several brake tests.
