SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: replacement steering wheel
Old Mar 8, 2019 | 03:32 PM
eddieducati's Avatar
1984 380sl
smaller steering wheel for 1984 380sl. I am looking at the cheap (under $200) steering wheels to replace the way too large stock wheel. It looks like the mounting hubs sell for about $75. Is it that easy? The wheels have a central horn button. Will that function without retiring or needing unobtainable parts? Any info appreciated from those who have made this modification. Thanks. Eddie
Last edited by eddieducati; Mar 8, 2019 at 06:12 PM. Reason: Posted before complete
Old Mar 8, 2019 | 06:21 PM
Arizona Mike's Avatar
1988 560SL, 2017 SL 450, and a few Corvettes
Before you order a smaller steering wheel, do make sure the top won't keep you from seeing the speedometer.
Old Mar 10, 2019 | 04:08 PM
myway's Avatar
450SL
Smaller wheels will interfere with speedo view to varying degrees depending on driver size and wheel size. They make an offset adapter to raise the wheel a little.
Old Mar 10, 2019 | 06:47 PM
1984 380sl
Thanks, but...
Thanks for the replies, but I would like to know if the available aftermarket wheels and hubs are a bolt on deal or whether it is more complicated, like having to rewire the horn. An adapter to raise the wheel is interesting, but I can’t find who might sell that.
Old Mar 10, 2019 | 08:03 PM
myway's Avatar
450SL
The hub uses your existing bolt and wiring. Momo sells wheels, hubs and the offset (eccentric) spacer.
