SL/R107: Exterior Light Failure Indicator Lamp is on...
Mercedes-Benz 560SL, Honda S2000
I'm hoping for a quick solution to this:
The Exterior Light Failure light comes on when I press the brakes and then stays on. I have checked & rechecked all of the lights, and everything is working as it should. Any ideas?
I had problems with the warning light but not on the brake light. What I found was that over time the solder joints in the "indicator module" (under the passenger side carpeting had cracked. I removed the module (not fun), resoldered the joints and the problem went away
RZKTex (10-05-2019)
