SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Check My Work, Please - AUX Fan Inop
Old Jan 6, 2020 | 08:29 PM
Cougar6's Avatar
2002 ML320, 2010 ML350, 2010 E350, 1987 560SL
The Aux Fan on my 1987 560SL is not turning on when I run the A/C. The engine gets hotter when idling and at low speeds.
I checked the voltage across the "jump" and it shows 13 volts going to the AUX Fan. Is this the last connection where voltage flows to the AUX Fan motor? In other words, if this is the last connection where volts go to the Fan, then if the fan isn't running, the fan motor must be bad?
If this test shows the fan motor is getting voltage, then the fan motor must be bad? Thoughts? Advice? Thanks!
(To the Goober who painted my car, you didn't have to paint the AUX Fan and Crossmembers).
Old Jan 7, 2020 | 01:24 PM
myway's Avatar
450SL
You have the probes reversed. That's why it shows -13.92. Does it still show voltage after jumping?
Old Jan 10, 2020 | 09:21 AM
Cougar6's Avatar
Yes, switching the probes results in +13.9 volts.
