SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 1989 560SL heat problem
Old Jan 31, 2020 | 11:06 AM
tdpole1's Avatar
1989 560SL
I just rebuilt the monovalve and have hot water going to valve and coming out of the valve, disconnected the wire to the monovalve so it stays open. The wire has power on it whether the control panel is set for heat or AC which I know should not be and that is why I disconnected it. It is my understanding the the default of the monovalve is open when wire not attached. The water circulation pump is running as it should but I am not getting any hot water to the heater core and it is pulsing like there is air in the line. Is there some other valve in line to the heater core that could be causing water to not reach the core. I am guessing that there is something wrong in the climate control panel but could sure use some direction from one of the senior members.
