SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Steering box again
Old Apr 20, 2020 | 12:50 AM
Jeff Webster's Avatar
1977 450sl
Steering box again
I have been reading lots of different ways to adjust your steering box but i have a question that i can not find an answer to.A lot of the info says to loosen lock nut and adjust with 6mm allen,but they says to turn the allen counterclockwise which to me doesnt make sense as that will be take tension of the gear.Domestic say to tighten the allen which makes more sense .Any input would be welcomed 1997 . Also i purchased some of the cheap centre caps and they are to small and fall inside but i measured the opening and it is 75mm as advertised but i think they are showing the outside and not the part that holds them in.
