SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: #7 Fuse blowing
Old Aug 23, 2021 | 09:38 AM
al300sd's Avatar
83 300sd, 88 560sl, 14 e550
#7 Fuse blowing
Hi all, i have an 88' 560sl, I keep blowing the #7 fuse i disconnected what i could find Aux fan, washer heater, tail lights, climate control i have the entire interior out so all the wires are more or less exposed and i am not finding anything.... I need help.....
Old Aug 24, 2021 | 06:58 PM
billygoat33's Avatar
1958 180D, 1959 190D, 1960 190D,1986 560SL,2007 S550,
I bought a 12 volt short finder years ago at an auto parts store - I see the same one on Amazon for $33. Jump the fuse with the aligator clips, then run the meter along the wire. When the meter dives,you found your short.
Old Aug 24, 2021 | 07:32 PM
al300sd's Avatar
Funny enough I did the same right after posting this I should be getting it on Friday I'll let you know what happens..... 🤞
Old Aug 29, 2021 | 09:04 AM
al300sd's Avatar
Hey everyone im still on this now using a short tracer. I need help locating a few modules.
1 Light Monitoring unit/ module
2 Shifter Switch
3 Warning Module
Thanks all
